Smøre pakninger?
  • Smøre pakninger?
    nu jeg skal til at samle motoren skal jeg lige høre om
    i smøre pakningerne med noget, olie, fedt, flydende pakning,
    wd40 eller lign? eller montere i dem bare tøre?
    // fandt dette på nettet...
    If you are going to be a good mechanic you've got to put away childish things. One of these things is using gasket cement everywhere. Gaskets are made to expand just a little when oil hits them. This makes a good, oil tight seal. If your sealing surfaces are smooth and you have a new gasket, you simply do not need gasket cement. A real sign of an amateur is lots of slobbery gasket cement. So do you put the gasket on dry ? No, you use plain ordinary wheel bearing grease. I use grease on all new gaskets except the ones that come from the factory with a special coating already put on. The grease serves several functions.
    1. It will hold the gasket in place as you put the two pieces together.
    2. It allows the gasket to move around a bit as you put in the screws.
    3. It starts the swelling process that the oil will finish.
    4. It allows you to disassemble things easily if an error is made and allows you to reuse the same gasket after you fix that error. Not that I ever make errors... well... I did once. I thought I had made an error, turned out I hadn't !
    5. It allows easy disassembly in the dim, dark future.
    Is there a time to use gasket cement ? Yes indeed. If there is a gouge or nick in the sealing surface, it will need to be filled in gasket cement. Sometimes no gasket is called for and the two parts are sealed with a gasket cement. There are many types out there. Get several that are sold in your area and see which one you like. I prefer the non hardening kind and I don't like any of the silicon seal types. The silicon seal types tend to ball up inside the engine and come loose plugging the oil screens and choking off the oil flow... not good. I really like YamaBond #4. It's a gray gooey cement used to join the crankcase halves of Yamaha 2/strokes. It doesn't ball up. Any excess inside the engine seems to flatten out and sticks to the side of the crankcases. I use it for any metal to metal sealing jobs where there is no gasket. I use it even if another sealant is called for because it works so well. Works good with gaskets too. You can get it from Yamaha. I don't use the silicon seal stuff at all. Not any brand... too many baaad experiences !
    “It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.” Mark Twain
    Smør pakninger
    Jeg smøre altid pakninger med en motorolie, brug aldrig WD40 der er op til 20% terpentin i den som udtørre pakningerne, vær også opmærksom på at WD40 påvirker gummi og gør det mør og indsugningsgummi bliver utæt
      Gammelt brokkehoved er enig
      " der er op til 20% terpentin i den som udtørre pakningerne"
      Ja og resten er bare almindelig petroleum. I mine øjne er WD40 et af de mest velgennemførte fupnumre.
      HVIS man smører sine pakninger med noget, er det i hvert fald vigtigt hverken at smøre for lidt eller især for meget, så snasket løber rundt indeni motoren og stopper til og sviner.
        takker - er heller ikke stor tilhænger af wd40 ..
        jeg talte med en som ofte sprøjtede sine pakninger med
        flydende pakning - den fra loctite - evt. kun på den side som "ikke skal af" når man feks tager sideskjold af - så bliver pakningen hængende på skjoldet.. ellers siger han også lidt motorolie på ...
          Jeg gør tit det modsatte, især med kork eller pap pakninger, Jeg smører fedt eller olie på den side, der gerne må slippe og lader den anden side være helt ren og affedtet, så den bider godt fast i pakfladen.
