Vigtigt. Forum er åbent for, at man kan læse alt, dog ikke dokumenter vedrørende klubben. Du skal være medlem af klubben, hvis du skal skrive på /oprette emner. Når du har fået medlemsnummer kan du oprette dig
her. Se forsiden mht. at melde dig ind. Link til indmeldelses information.
Håber du kan læse engelsk, for her er et uddrag som skulle forklare funktionen.
A lot of people ask about the Yellow wire coming off the stator. This goes to the safety relay. What does the safety relay do? Well, the yellow wire taps into the stator charging coils (White wires) and puts out a voltage telling the safety relay the motor is running and the alternator is producing voltage. It in turn disengages the starter circuit so's not to grind the starter gears and on some models it also turns on the headlight circuitry. Tests show the voltage on the yellow wire while the engine is running should be around 6 to 8 volts depending on engine rpm. The safety relay pulls in at around 4 volts. Also, based on it's operating voltage I don't think the safety relay's coil is designed to be connected to 12 volts, at least not long term. So bear this in mind.
OK.... Put voltage on the brown wire,.... get higher voltage out on the red. And the green turns the rotor on and off. Simple Huh?? Takes a little studying but you'll get it. So.... Now that we know WHAT it's supposed to do and if your having problems, let's see what,.no, WHY it isn't doing it's thing. For this refer to my Next Page "Troubleshooting Your Electrical".....
Eller på dansk: Det omtalte relæ, er et sikkerhedsrelæ, der skal forhindre, at du indkobler el-starteren mens motoren kører. Hvis du da ellers kunne finde på at gøre det (nok mest tilegnet XSessister med kraftig nedsat hørelse).
P.S.: Du spørger om det kan undværes. Ja, det kan det godt, men så er den bare ikke længere helt idiotsikret.
'Best thing I ever rode.'Kenny Roberts.
Jeg havde fået det samme svar af Per fra Ringsted idag da jeg havde kontakt til ham alligevel. Jeg havde nu heller ikke stikket hvor det skulle monteres.
Mvh Nich[]
